John Deere
   / John Deere #1
Ken Hopkins
John Deere X304
While mowing, have broken 3 belts, one that I had been using for two years and two new ones , all replaced by lawnmower repair shop.
John Deere X 304 4 wheel steering
1025 hours, year 2006.
Pulleys and tensioner are A OK.
Any suggestions as to cause of my problem?
   / John Deere
Added info: The belts didn’t break when engaging or disengaging the blades but but each time broke while mowing a strip of grass at 3 1/2” as I have been for years - just taking off the top 1”.
   / John Deere #3
Could be the blade spindles. Not sure if the shop checked them? Sometimes spindles can feel ok until you put a perpendicular load on them as in the belt being hooked up. When was the last time they were greased?
   / John Deere #4
Do you throttle down when starting the blades? I know you say they are not breaking then but it may still be hard on them.
I had a Kubota BX that went several years on the original deck belt, then I went through two more quickly, then the 4th one lasted a long time. I think the two that didn’t last were defective, a run of bad belts.
   / John Deere #5
Check for something jammed into the root of the pulley like a rock, wood, piece of old belt.
   / John Deere #6
So you are talking deck belts on a 42" deck? If not, be more specific. If so, your friendly Deere dealer has a bulletin. It involves a new guide kit and inspecting the tension arm for wear etc. - which is very likely at the hours. X300, X304, X310 42C deck belt failure Solution 116525
   / John Deere #7
Are you buying kevlar deck belts?
   / John Deere #8
I have a machine exhibiting the same issue as the OP. (X300/42C W/o Tensioner Handle) 350 Hrs.
Never had this before then all of a sudden 4 belts in 2 weeks.
I have researched the post by Tom and sourced the DTAC Solution from the dealer. It is dated 2019 and that's after I left working there so it is 'news' to me.
There is obviously a problem sufficiently widespread for JD to devise this modification and produce a new guide plate.
Thanks Tom. I've ordered the part and will report back.
Hope this helps the OP as well.
   / John Deere #9
Could someone please post the part numbers associated with X300, X304, X310 42C deck belt failure Solution 116525? This is costing a small fortune in belts.
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
2014 Ford Escape SUV (A51694)
2014 Ford Escape...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
2008 CATERPILLAR 272C SKID STEER (A51246)
2008 CATERPILLAR...
Diesel generator crank no start (A51691)
Diesel generator...
