jpc6759
Mowing grass yesterday with my Z915B zero turn and ran over a branch I didn't see in high grass. Before I knew I ran over the branch the tractor just all of a sudden bogged down. Thought it was the high grass so I stopped and backed up a bit out of the high grass. Motor still seemed bogged down so I shut the blades off. The motor then revved back up and sounded fine. Once I tried moving, however, the motor bogged back down. The faster I tried to go the more it bogged down. I limped it back to the house and found the branch jammed in the mower deck. I've since cleaned it all up and removed the mower deck belt from the motor but I still have the issue of the tractor bogging down as I try to move. Sounds the same as if you get in real high grass. Any suggestions on what the issue may be? was thinking that I possibly did something to the clutch for the deck since it would still be with the motor after removing the deck belt.
