Buying Advice John deere tractor help ASAP!!!
   / John deere tractor help ASAP!!! #1
hhawkeye21
Im thinking about getting a John deere 950 it has 5225 hours on it. It also has a Yanmar diesel engine. Would I have any issues with how many hours are on it.
   / John deere tractor help ASAP!!! #2
Yanmars are outstanding engines, but that is a lot of hours.
How well the engine was maintained means a lot...but frankly, I wouldn't buy a tractor with that many hours on it. Even if the engine is OK, you still have to consider the rest of the drive line and other components of the tractor.
   / John deere tractor help ASAP!!! #3
That's a lot of hours on a small tractor.
Even if the engine was babied other items being worn like clutch, brakes, bearings, seals, etc would be suspect.
If you were looking for a stationary power unit to run an irrigation well or something and it was cheap enough yes, if you are looking for a tractor to use normally I would pass.
Does the seller know how it got so many hours?
We were just going to use it for mowing and pushing dirt around
   / John deere tractor help ASAP!!! #5
Well, you have a couple of responses with our opinions. Now, you have to make your decision....good luck!
Im not sure what he used it for.
:confused:
yes thank you for all the responses
   / John deere tractor help ASAP!!! #8
That is what most of us do with tractors, as you get more involved you find more things to use it for.
I agree it is alot of hours but if your budget is limited and the price is low it is worth considering. What is the asking price and what kind of condition is it in? If you don't know you may want to have a good mechanic check it for you.
   / John deere tractor help ASAP!!! #9
Hire a mechanic to go over it. Worth at least a $100 or more for a professional opinion. Lots of hours, especially for a machine that size. It would have to be cheap.
At one time, there was a thread about how much money should be deducted for X number of hours off of a price. For newer equipment with low hours, I think it was around $10/hour. For older stuff with low hours it was like around $5/hour. But for 5225 hours, it would have to be almost free. Somebody, somewhere has gotten their $$$ out of it. I would pass or not give much for it depending on condition.
JLG 20MVL Electric Vertical Mast Lift (A50322)
JLG 20MVL Electric...
2003 Chevrolet Express 1500 Cargo Van (A50323)
2003 Chevrolet...
HLA 84" Skidloader Material Bucket (LIKE NEW) (A50774)
HLA 84" Skidloader...
Ez-Go Shuttle 2 Electric Golf Cart (A50121)
Ez-Go Shuttle 2...
1994 Peterbilt 379 Semi (A50514)
1994 Peterbilt 379...
John Deere 7130 Loader Tractor (A50514)
John Deere 7130...
