John Deere STX 30 lawn tractor
   / John Deere STX 30 lawn tractor #1
Patches
Veteran Member
So. Maine
Kioti 3054xs TLB
I have the above mower and the trans/axle crapped on me; looking for a replacement of this 30yr old piece, but don't where to look. STX 30 and STX 38 utilize the same Peerless unit. Before you tell me to junk it, the rest of the mower is still in excellent shape and I'm 82 years old so not going to spend $5000 + on a new one ----- unless I have to
   / John Deere STX 30 lawn tractor #2
Did the transaxle actually fail or is it simply out of fluid? I have a Craftsman that lost its fluid. I can't get seals for it but it does have a fill port on the top. I drilled lower down for a hydraulic jack plug to check fluid level. I'll get a bit more life out of it - perhaps enough to outlast me as I'm 78.
   / John Deere STX 30 lawn tractor #3
Try here. I have bought from them in the past. Good people.
   / John Deere STX 30 lawn tractor #5
Those yellow deck STX's are unbelieveable mowing machines.... very hard to kill. Did you call JD and see if it is still in service? Peerless is still making manual transaxles... maybe you could get service parts (or a.replacement) directly from them.
   / John Deere STX 30 lawn tractor #6
You may find a used transmission on Amazon or E-bay.
Thanks for that info; was unaware Peerless is still around
Thanks, but I have a difficult time purchasing something I can't see from someone I don't know
   / John Deere STX 30 lawn tractor #9
What's wrong with the transmission? I've had several not shift due to the grease drying out after 20 plus years. Splitting the transmission (not hard) and repacking with 00 corn head grease can be a remedy.
Thanks for that. I've been in the case once to replace two fractured shift keys about 12 years ago and filled it with corn head grease then. I have the unit out, but have yet to take top case cover off; too da--d hot
1996 Chevrolet IMPALA SS (A51222)
1996 Chevrolet...
John Deere 893 Corn Head (A50514)
John Deere 893...
2015 KENWORTH (INOPERABLE) T880 (A50854)
2015 KENWORTH...
Stainless Steel 1" Spool (A49461)
Stainless Steel 1"...
Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
Bad Boy Outlaw XP...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
