John Deere Snow Plow
   / John Deere Snow Plow #1
jgbanshee
PA
JD 310SE, 4300, 5300, 5210, 450 Crawler, CAT D3B, Ford 2N, 5000, 4000su, 3610, 345C, 340B, 1100
Are the mounting brackets on the snow plows for the JD 400 series tractors the same as the 300 series tractors? In other words, will a snow plow from a 400 series fit on a 300 series tractor and are the hydraulics the same?
   / John Deere Snow Plow #2
I don't beleive they are the same, but you'll need to check the Deere dealer for certain. One series has dual hyd. control and except for the 345, I don't think the 300 series has it. But not all that familiar with the 300 series. I am assuming the 400 series you speak of is the 425, 445, and 455. The hitch on the X series is again different, as it accomodates a different PTO shaft to the blower and sweeper. However the 400 series will fit on the X, whereas the reverse isn't true.
   / John Deere Snow Plow #3
The 54" plow itself and the cylinders to raise and angle it are the same, but the hitch to the tractor is different as the frames are different. It would help to know what model of the 400 series you are comparing with as there are variances in the 400's.
   / John Deere Snow Plow #4
I think we need some clarification here.
Do you mean the old 300 series and 400 series (316, 318, 400, 420, 430, etc.. ) or the new series.
   / John Deere Snow Plow #5
I have 318 and plow controls are hooked to hyd system. I didn't buy the plow
from neighbor and he still is trying to sell cab and plow as I only wanted the tiller and mower with it.
Peterbilt 377 Semi-Truck (A52748)
Peterbilt 377...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
Skid Steer Quick Attach Jack Hammer (A50515)
Skid Steer Quick...
2016 COTTRELL EZ5307XL CAR HAULER TRAILER (A52141)
2016 COTTRELL...
2014 Ford Fusion Sedan (A50324)
2014 Ford Fusion...
Concrete Trowel (A47384)
Concrete Trowel...
