Does anyone know if a rebuild kit is available for a John Deere Sabre with a B&S 15 hp engine, model # 28N707, type 0635 A1, code 9510254B. Thanks for any help.
I have a 2002 J.D SABRE riding tractor with a 14.5 hp briggs...approx 375 hrs on meter...I removed the mower deck with intentions of replacing...42" cut...was bent..Anyway-we drive the kids around on it and drag a small pull cart behind it ocassionally...has 5 forward and reverse gear...electric start...
Taking up space in the garage...FOR SALE...if interested...
PM me if u'd like....I think your in the JAX fl area?....
What's wrong with the engine? Why do you think you need a Kit? I have one of those engines on a Dixon mower and I blew a head gasket once and it smoked so bad I thought it had blew up, it had tremendous blow by. I had the head gasket replaced and runs great now. These engines have a compression release that require the valves to be adjusted frequently or the motor won't turn over and you'll burn out the starter tryin' to start it, Don't ask how I know this. expensive engine maintenance lesson. bjr
I have a 15 hp Sabre engine model 28n707, type 0635 A1, Code 9603224A. Is it interchangeable to a 14.5 hp Model 287707, type 1274 E1, code 98091220. Need to know is the mounting bolt holes are compatable.
