John Deere S1400 weed eater string spool issues
   / John Deere S1400 weed eater string spool issues #1
nickel plate
Veteran Member
CA
2002 New Holland TC40S
Either I'm not doing it right but I have virtually ground down the original "bump head" spool. The string tangles up internally like a casting fishing reel's "birds nest" constantly. Short of schooling me (please but optional) on how to wind the .095" string on properly and not destroy the bump head by banging it into oblivian, is there an aftermarket 8"+- two string head made for this model? The type when the two 8"+- strings wear down you shut it off, pull out the old worn down two string nubbins and replace with two new 8" strings.
The steel or composite blades are not an option as we have a lot of rocks and dry brush-don't want to start the forest on fire or blow up on the rocks a pricey set of rigid blades from the get go.
WACKER NEUSON EZ36 EXCAVATOR (A52705)
WACKER NEUSON EZ36...
2016 Freightliner M2 106 Ambulance (A53422)
2016 Freightliner...
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
Hose Reel (A53424)
Hose Reel (A53424)
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A54814)
2014 Peterbilt 384...
