John Deere pops out of gear
   / John Deere pops out of gear #1
steviep
Milton NH
2001 JD 4300
My 2001 John Deere 4300 with sync reverser keeps poping out of 2nd and 3rd gears and it doesn't matter if it is in range A,B,or C . Sometimes the foward / reverse lever will also pop out of gear. does anyone have an idea of whats happening. And how to fix it
   / John Deere pops out of gear #2
Dealer time. I suspect a syncro gear is worn out. Although for only 7 years of service it seems odd. I've got (besides my JD) a 1973 economy/power king tractor (14HP) with tandom transmissions (9x3) on one set of gears it will either slip out or lock up in gear. Not worth my time to fix it as I rarely use that gear.
Good luck.
   / John Deere pops out of gear #3
I have a Kubota M4800 that is popping out of low range. 340 hrs and 4 years old. :mad: I spoke with the Service Manager at the dealer and he told me that there is a spring that holds tension on the lever that could be broken. He also said it could be a synchronizer. If I hold pressure on the lever when letting out on the clutch it doesn't do it. I'm waiting for their slow time to repair it this winter.
Chris
   / John Deere pops out of gear #4
My brother bought a 1976 Zetor 6718 with 9800 hrs on it cheap, because it popped out of 5th. (he traded a ferguson TEF against it, converted with a Perkins P3 that smoked as much from the crankcase breather as from the exhaust)
It was caused by the fuel tank/dashboard rubbers that were sagging, causing it to hang against the dashboard mounted gearlever.
With the tank/dash rubbers replaced it still popped out. We opened the transmission and found that meanwhile, a 5ct Seeger retaining ring was missing of the 5th speed shifting collar. It took 4 evenings to fix it, it could have been done quicker if the previous owner used new rings remounting the other parts after trying to fix it himself: We found tack welded retaining rings in the transmission, as far as it was straightforward. (you could see that the retaining rings were damaged from screwdrivers, instead of proper pliers) When he got to the point that you need to pull out the PTO shaft from behind, to drop the PTO gears in front of the travel gears, to get access to the main gearbox, the guy gave up and put everything back together, tack welding the retaining rings instead of putting in 3 dollars of new rings :p
We restored the tack welding by the previous owner, by some more proper retaining rings, shimmed the play out of it, and this 70 hp tractor is doing everything from pulling 16 ton dump trailers to land levelling and wood chipping for a highway maintenance crew... ;)
After a total rebuild of my 3011 transmission last winter, i can dream these transmissions and probably rebuild one in a day, not counting the time to pull the gearbox from the tractor.
2025 IR UNUSED Hydraulic Thumb (A53117)
2025 IR UNUSED...
2014 Ford Taurus AWD Sedan (A51694)
2014 Ford Taurus...
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
378813 (A51573)
378813 (A51573)
2007 GMC Sierra (A50123)
2007 GMC Sierra...
2008 CHEVROLET C7500 BUCKET TRUCK (A51406)
2008 CHEVROLET...
