John Deere mx6 brush cutter behind L4060
   / John Deere mx6 brush cutter behind L4060 #1
TxMN
Bronze Member
North Central Texas
2020 Kubota MX5400 HST, ROPS, 2020 Kubota RTV 900, 2020 Kubota RTV 500(wifeç—´ ride),
Your thoughts on this combination for 20 acres of mowing, JD says minimum 30 HP for this mower. Am considering L 4060 with 300 hours and this mower in a package deal. Concerned if they will perform well together. Tractor also has glide shift, if that would make any difference in performance with this mower.
Still looking for the right tractor for new property, have gotten great inputs from members of this forum, thanks to all.
   / John Deere mx6 brush cutter behind L4060 #2
My thoughts are, with all the MX6's that have blown up the gear boxes, I'd be buying a Woods Brush Bull to go behind that tractor!!
SR
Did not know that, would a 5 ft mower be a better match, no matter the brand? I don’t like to push to the equipments limits and not get full performance out of tractor and mower.
   / John Deere mx6 brush cutter behind L4060 #4
As Rob says, buy a different mower.
I run 5' RC (Landpride 1260) on my B7800 (23hp PTO): for years and doing some pretty tough duty, I ran a Rankin [which was really only light duty]). Run a 6' RC (Bush Hog BH286) on my NX5510. It all depends on what you're cutting and what speed you're looking to cut at.
My BH286 was used commercially before I got it and it looks the part! Previous owner had 1/4" plate steel welded to the top deck (likely because the original decking was getting punched through). After putting a few bucks into it (bought it for $800) and have a mod to the tail wheel bracket (to strengthen) it's now totally brush-worthy, pretty much indestructible. QH compatible it ain't, which is the only downfall, but my NX has adjustable link arms and that makes for fairly easy hook-ups.
Concentrate on what job you need to do and what tractor; THEN worry about what implements (a used RC is generally fine, though as has been noted, the MXs are something that one would be better off staying away from).
   / John Deere mx6 brush cutter behind L4060 #5
Field conditions matter more than the HP or mower width. Here is dry Colorado I run an Peruzzo Brush Bull 2200, working width 87" behind my 40hp L4060. It does fine for the sparser fields & brush around here. My L4060 struggles mightily if we get thick grass though & I end up going really slow. If we were on the coast where their grass gets water I'd need a smaller mower.
If you go to wide you can just slow down. Trivial with a HST, not to hard with a GST. I prefer wide & slow to narrow & fast. Less bouncing all over for me & my machine.
2015 Jeep Wrangler Multipurpose Vehicle (MPV), VIN # 1C4BJWEG5FL757630 (A51572)
2015 Jeep Wrangler...
2017 Peterbilt 567 Day Cab (A52384)
2017 Peterbilt 567...
2016 Hino 195h Truck, VIN # JHHSPM2H6GK001602 (A51572)
2016 Hino 195h...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
New Long Forks (A53002)
New Long Forks...
