John Deere mower blades for 54 inch Edge High Capacity Deck
   / John Deere mower blades for 54 inch Edge High Capacity Deck #1
bob3275
JD X590
I have found 2 blades for my 54 inch Edge High Capacity Deck on my X750. One is an M164016 and the other is TCU30316. Length and hole size is the same The TCU30316 blade is 1/4" thick and the M164016 is 13/64" thick. The width of the M164016 is 2 3/4" while the TCU30316 is 2 1/2". The "height" of the M164016 is 1 25/64" and the height of the TCU30316 is listed as 37/64", which is significantly lower. Interesting to me is that both blades are listed as "standard". Please tell me what the difference would really be between these blades for cut quality, etc. Thanks!
   / John Deere mower blades for 54 inch Edge High Capacity Deck #2
Is one set for mulching and the other for bagging .......:confused3:
Just ordered a set of each of the blades.................will figure this out one way or another.........lol
   / John Deere mower blades for 54 inch Edge High Capacity Deck #4
That works now you have a spare set........
   / John Deere mower blades for 54 inch Edge High Capacity Deck #5
According to JD Parts:
Part Number: M164016
Description: Blade - BLADE, BLADE, SIDE DISCHARGE 54HC
Part Number: TCU30316
TCU30316 Blades Blade (54" Deck) (Standard)
TCU30316 Blades BLADE - HIGH LIFT
TCU30316 Mower Deck Parts BLADE - MEDIUMLIFT OPTION (3) (54”)
It appears they can't decide what TCU30316 is for. :)
2022 MST 660VD Tracked Dump Truck  Only 30 Hours (A44789)
2022 MST 660VD...
2024 VALLEY PIONEER C08 MINI DUMPER (A45046)
2024 VALLEY...
2021 Bobcat E145 Excavator (A42203)
2021 Bobcat E145...
Mitsubishi FG35 Forklift  8,000lb Lift Capacity, LP Gas (A44789)
Mitsubishi FG35...
2015 FREIGHTLINER CORONADO 122 SD (A45333)
2015 FREIGHTLINER...
2016 Ford F-150 Pickup Truck (A42744)
2016 Ford F-150...
