John Deere LX277 Starts eventually...
   / John Deere LX277 Starts eventually... #1
Mike05
Denton, TX.
John Deere LX277
New to the forum; looking for help with a John Deere LX277.
It's a starting issue; eventually it turns over and starts but (it seems) only after sitting with the key on for several minutes.
Once running there's no issue, starts/stops just fine. But after sitting idle for a few days, go to crank it & nothing happens, just a single "click" sound. Eventually it starts but I'd sure like to fix this! As it is I twist this, lower that, even unplugged the auto cut-off switch under the seat (that time it fired up but had to be plugged in to engage!) so I'm lost.
Lastly, it seems like if I quit clicking away & just leave the key on it eventually starts. Does that make any kind of sense?
New battery too. Maybe a starter solenoid?
Thoughts/suggestions appreciated.
   / John Deere LX277 Starts eventually... #2
Those starters have to get ALL 12 volts to work . With 2 or 3 safety switches for current to go through that doesn't always happen .There is a fix . Wire a small 4 post relay into the starting circuit and problem solved . I found this in an old thread on My Tractor Forum . com . Showed the relay and how to wire it .I did it to my stx 38 and never had another problem . I think Deere sells it as a starter improvement kit also . Ijust bought the relay online for 4 bucks .Took about 20 minutes to do . Hope this helps .
   / John Deere LX277 Starts eventually... #3
Yep , go to MTF.COM . Click active topics , click last day, top middle of page google stx38 starter fix . I think you have a Kawasaki engine instead of kohler , but same principle applies . Good luck .
Thanks! I'll try it this week & let you know how it goes.
Unfortunately I can't find the web site you refer to: "MTF.com" Any chance of getting the full address?
Thanks.
Husqvarna 128CD Weedeater (A48837)
Husqvarna 128CD...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A48837)
IMPORTANT PLEASE...
2014 Ford Econoline Enclosed Tool Body, VIN # 1FDWE3FL9EDA04865 (A48836)
2014 Ford...
2006 Ford Explorer 4x4 (MPV), VIN # 1FMEU73E36UA28575 (A48836)
2006 Ford Explorer...
197652 (A50458)
197652 (A50458)
2008 John Deere 3520 Tractor (A50860)
2008 John Deere...
