John Deere Lube
   / John Deere Lube #1
317140
Bronze Member
North Carolina
John Deere 3520
I am getting ready to change oil and filter in my 3520 for the first time. The Dealer recommended changing it after 10 hrs. I went to the Dealer and bought oil and filter. Kind of pricey. I was wondering if anyone knew who manufactured oil and hyd fluid for JD. I was thinking I could save money and time by buying oil and hyd fluid from Auto Supply Store or Discount Store. I want to use correct oil and fluid, just looking to save a few bucks. Signed Cheapskate
   / John Deere Lube #2
"The Dealer recommended changing it after 10 hrs"
Your manual states to change the oil and filter aftyer 50 hours. Your manual states to check the oil after ten hours.
I think you may have misunderstood your dealer, or he's giving you some bad information.
Those engines need that break in oil for the first 50 to 60 hours. I strongly...strongly...suggest you go with your manual!.
   / John Deere Lube #3
I've just changed oil at 50 hours in my 3120 which is per the manual. I thought the 3X20's shipped with break-in oil. Why would your dealer recommend changing this at 10 hours?
Anyway, I bought the oil filter from the dealer. Just a tip, my manual says to use PN M811332, which doesn't appear to exist. The correct JD PN appears to be M806419. It's slightly smaller in diameter than the one it shipped with. I also would like to know who makes this.
For the oil, the manual says any oil meeting specification E3, E4, E5, CI-4 and CH-4 may also be used. Many different opinions on which oil is best. I picked Amsoil 3000, 5W-30. Not cheap but neither is the tractor.
2015 Ford F-550 Crew Cab Mason Dump Truck (A51691)
2015 Ford F-550...
2018 Infiniti Q50 AWD Sedan (A51694)
2018 Infiniti Q50...
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
2005 INTERNATIONAL 9400I TANDEM AXLE SLEEPER TRUCK (A54313)
2005 INTERNATIONAL...
2000 GMC C7500 CRANE TRUCK (A51406)
2000 GMC C7500...
2018 MACK CHU613 DAYCAB WINCH TRUCK (A53843)
2018 MACK CHU613...
