Mowing John Deere lt 155 help
   / John Deere lt 155 help #1
DABSGT
Veteran Member
Connecticut
John Deere 2032r
My son has a JD LT155 and called me because of mower deck failure. The tractor runs fine but when engaging the deck the left blade not turning. I will be looking at it next week (when he gets home from honeymoon). He said right side turns no problem and cuts. Is there a second belt or a pin? Any help appreciated.
   / John Deere lt 155 help #2
Sounds like he was trying to mow while on his honeymoon. Hmmmm??
Only the one timing belt keeping the blades separated. Tough to think that belt is driving one blade and not the other.
Maybe the bolt/screw holding one blade on is not tight (or wasn't tightened) and one blade free and hanging loose on that bolt, thus free to drift. There are no pins in the spindle shafts.
If free, then there may be a worn spindle shaft now, keeping you from getting the two blades back in time with each other.
Thanks for the info. He is on the Mexican coast now. I'll need to check next. Week
Split Weight & Wheel Weight (A50515)
Split Weight &...
(10) 7 x 9 Treated Posts (A50515)
(10) 7 x 9 Treated...
2012 Ford F-450 Altec AT200A 30FT Bucket Truck (A50323)
2012 Ford F-450...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
PORTABLE METAL FUEL TANK (A51243)
PORTABLE METAL...
