I just put a new sump gasket and crank oil seal on a briggs 20 ho intek. after I put the engine back together when I start it it goes straight to full throttle//speed and will not idle down with throttle adjustment. i have gone thru the steps of setting the govenor base idle several times and nothing works,,,it always runs at full throttle. when i re-assembled the two parts of the engine did I do something to mess up the govenor on the inside? I need some help and insight if anybody has it to share.
Thank you
kdendy
What are the steps for setting the governor that you used?
Did you have the engine upside down when you pulled the sump off?
Did any of the governor parts come off with the sump?
I don't have a repair manual but a video on the net looked like it was possible to come off.
Are there any alignment marks on the governor gear pieces?
I may be doing the same tear down very soon as I have/had an oil leak dripping on the floor after use.
In fact, I have the gasket and seal. Mine has 900 hours on it and I thought it was the seal. When I called JD parts the guy said the seals
usually don't leak but the gaskets do. I ordered both as the old seal may get messed up and being 10 years old with 900 hours I would not want to have to take the engine out again.
I cleaned everything up and did find a loose sump bolt on the left side just to the front of the oil filter.after tightening it, in place, with a 13mm wrench which was a little loose fit but the closest, it has not leaked any oil after 3 hours of hard work.
I could not be that lucky:laughing::laughing: so anticipate using the parts sooner or later.
Did you use any gasket sealer on your new gasket?
Mine came dry and the parts guy was surprised that there was not a little pouch of sealer in the envelope.
Did you learn any tricks or shortcuts for pulling the engine and putting it back on the tractor?
As the parts guy said, "that's the hard part."
