John Deere Hay Cutter
   / John Deere Hay Cutter #1
rwestbury
Is there an advantage of a John Deere 935 Rotary Cutter with Flail Beater over the standard sickle cutter with drum roller/crimper? I am looking for a cutter and have run across the JD 935. Will the Rotary/Flail wrok well since I will be cutting coastal grass only?
Ron
   / John Deere Hay Cutter #2
Welcome to TBN. You might get alot better feedback if you (or moderator) moved this post to the Ag section.
More knowledgeable farm-types that can speak to the pros and cons of the 935 with a flail cutter vs a sickle bar type cutter-conditioner.
AKfish
2016 Caterpillar 349FL Hydraulic Excavator (A53421)
2016 Caterpillar...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A55787)
2020 Kubota Z723KH...
2017 Ford F-550 Crew Cab Enclosed Service Truck with Liftgate (A53422)
2017 Ford F-550...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
