"Tractor" (it's only 13 hp) will not start.
Mechanically inclined woman here, but I'm confounded by this! I know enough to venture in, but also enough to be dangerous.
REPLACED:
ignition switch
solenoid
seat safety switch
fuse (it was blown)
TESTED:
* Starter - it seems fine (removed from tractor & wired to a battery)
----- able to jump start it through the solenoid - then runs fine
* PTO Switch - works as should
* Neutral Start Relay - works as should
* Seat Safety harness - works as should
Battery reads 12.5 volts, starter side of solenoid reads the same, however the other top & bottom pole on the other side doesn't read anything with ignition switch on start ... not sure if it should (the left side small contact is connected to the ignition switch).
Cleaned Ignition Switch contacts.
I've downloaded the Tech Manual which has helped me perform a couple of the tests, but still coming up short.
I don't know where to go from here ... help would be greatly appreciated. Thanks!
REPLACED:
ignition switch
solenoid
seat safety switch
fuse (it was blown)
TESTED:
