deere5105
Veteran Member
- Joined
- May 6, 2009
- Messages
- 1,086
- Location
- South Mississippi
- Tractor
- 2008 John Deere 5303 MFWD, 2004 John Deere 5205
Was recently discing a food plot for a friend and smelled diesel. Continued on with my discing as it was almost dark and couldn't see well anyway. When I loaded the tractor I noticed diesel was streaming out from under tractor. Got a flashlight and noticed there was a valve that appeared loose. I hand tightened it and it appeared to stop. Later at home I checked closer and it was a slow drip. I have since tried draining the diesel and adding teflon tape to the bolt. Yesterday I noticed it was still a little wet and I tightened up the hose clamp. Couldn't tell for sure, but it still appeared to be a little wet. The only other thing I can think of is to back out the bolt and drain the diesel again, put more teflon on the bolt, tighten the clamp as much as possible with the bolt not in and then replace the bolt. Anyone got any suggestions or ideas or had to deal with this before. This is a 22 gallon tank on 5105 John Deere. See attached picture for a visual of the bolt.
