John Deere F935
   / John Deere F935 #1
gobucks
Ohio
Just curious if anyone has any experience with the JD F935 front mount mowers, 72" deck, 28 hp deisel. I have seen one with 2600 hrs that looks like it has been well cared for. I know that many of these are abused pretty good commercially. Although I had heard people say that these mowers are pretty much bullet proof and 5,000 hrs could be reached without too many problems. The one I have seen does have 2600 hours on it. Just curious if these are good mowing machines and what a fair price would be for one with that many hours. I am looking to mow about 3 acres with it. Thanks for your input.
   / John Deere F935 #2
These are great cutting machines but with that many hours I would surmize that it has been used commerically. NOT a good thing. That is a LOT of mower just for 3 acres and you could cut that with a much smaller front mower. I cut more than that with my F525 which is a smaller front mower. Very good with trimming and tight spots. Unless you know a considerable amount of background info. on this F935 to indicate otherwise, I would look else where. Yes they do go over 5,000 hours if well cared for the but the well cared for part is rarely the case.
   / John Deere F935 #3
I used one for about 2 years. I only mowed about 1 1/2 acres, but it was a fantastic mower. This particular one had been used for mowing at my church for a few years.
You sure could get your mowing done quickly with it. I couldn't tell you much about the 2600 hours, other than it sounds like a lot.
As others have said here, get the serial #, go to your local dealer and see what they can tell you.
   / John Deere F935 #4
I tryed one last year for a couple weeks and it was terrible on the hills. The cut was ok but not any better than the 455 that I wound up buying.
8x18 Metal Rack Hay Wagon (A50774)
8x18 Metal Rack...
Ford F-450 Utility Truck (A52748)
Ford F-450 Utility...
1999 Ford F450 Dump / Plow Truck (A50514)
1999 Ford F450...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
John Deere 693 Corn Head (A50514)
John Deere 693...
2016 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER TRUCK (A52141)
2016 INTERNATIONAL...
