mlenkowski
I have a F935 that I purchased used with 2300 hours. The machine was in fair condition and I have replaced a good amount of parts to get this machine running at top condition; fuel lines, injectors, glow plugs, filters, valve adjustment, bearings, tires, etc. The machine runs well and I have a 72" side discharge mowing deck and 60" rotary broom, both in good shape. I have had a JD dealer go through the machine as well, giving it a thumbs up on status, including compression test on the yanmar. When using this machine I notice and experience the following that lead me to get other F935 owners thoughts regarding engine performance:
1. I have to start the machine at 1/3 or 1/2 throttle or else it's a very "rough" start, i.e. I can't start it with the throttle all the way down or else it runs rough until I give it more fuel. Once started I can set the throttle at the low setting with no problems.
2. When engaging the pto with the 72" deck I notice (hearing) a drop in engine rpm, maybe a few 100 rpms. I do not get this with the broom and I understand the 72" deck is a big attachment to get moving. This might be a sign of the motor adjusting to its torque curve, but I am not sure.
3. The mower performs well in normal conditions; dry to damp cutting 2-3" of grass. When cutting 4" or more of grass or wet to very wet grass the engine bogs down. It will produce black smoke when the load on the engine gets to be much. When it bogs I have to slow up a bit to let it catch back up. I do keep my deck scrapped and blades sharp.
4. I also have a F1145 and 855 CUT, both with the direct injection 3TN75RJ engine. When these machines get loaded I notice they bog down differently, mainly they work through it better, produce more black smoke, and recover quicker. They also start better. I do understand that they are bigger motors and are direct injection unlike the 3TNA72 engine. I just get concerned that I am missing something obvious on the F935 that can be easily resolved to improve engine performance.
I have checked and adjusted slightly the throttle cable and I have checked for air leaks in the fuel lines which are new from the tank all the way to the injectors. I have also replaced air intake hoses and I maintain very clean filters. I have not ventured into the governor or exhaust yet as there have been no major visible signs of issues that I believe to be causing anything to go wrong in these areas. Maybe these items I noted above are just the limitations of the 3tna72uj power plant in the F935. In any event I am looking to get thoughts from other users of F935s and tips on some checks I can run to make sure I am getting the most from the motor and that it is operating at its peak. Thank you
