John deere crawlers
   / John deere crawlers #1
Lazy
Platinum Member
Missouri
ford 1920 w/fel and bh, case 470, allis chalmers B 1937, JD 450 track loader, Case vac, 3 cub cadets ford lgt 125, Kubota 2230/60 inch mower.1948 farmall cub 1953 farmall cub
Hi
Can someone tell me the difference between a 450 b and a 450 c track loader?
Thanks Charlie
   / John deere crawlers #2
Hi Lazy; I'm not precise on this, but here is my best answer. Much of this you may already know:
JD 450 B manufactured from aprox 1970 to 1978?
JD 450 C manufactured from aprox 1979 to 1984?
The 450 C is a very slightly updated version. It is turbocharged. It has a 70 gross hp 4 cyl diesel. Weighs 16,700 lbs. 1.25 cubic yard bucket. Single lever loader control. Hydraulic track adjustment. Self adjusting steering clutches & brakes.
In contrast, I don't think the "B" was turbocharged, but most of the other specs are similar.
They are extremely useful machines. Parts can be expensive, make sure the undercarriage is in good shape....
   / John deere crawlers #3
I think the b models have dry clutches and the c models have wet clutches the wet clutches last about 3 times longer.
   / John deere crawlers #4
Thats the biggest difference between the two, always go for the "C" model if possibe, you can't beat the wet clutches.
1989 14ft. Gamefisher Aluminum Jon Boat with Trailer (A51694)
1989 14ft...
2010 LONE STAR TRAILER MFG. GOOSENECK TRAILER (A53843)
2010 LONE STAR...
2025 K731G UNUSED Flower Bed (A53117)
2025 K731G UNUSED...
2007 Dodge 3500, 6.7 Cummins, Automatic (A52384)
2007 Dodge 3500...
Brand New 5 gallon buckets (A53117)
Brand New 5 gallon...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
