Oct 22, 2020 / John Deere A throttle lever set screw #1 1 1952a New member Joined Oct 21, 2020 Messages 3 Tractor John Deere A I removed the set screw on the throttle handle, it is a step down type set screw. Is it supposed to screw into a hole in the rod or just act as a set screw? Thanks
Oct 22, 2020 / John Deere A throttle lever set screw #2 B beenthere Super Star Member Joined Aug 16, 2001 Messages 18,553 Location Southern Wisconsin, USA Tractor JD_4x2_Gator, JD_4300, JD_425, JD_455 AWS, added JD_455, JD_110, JD_X485(sold) :welcome: to TBN Remove the lever and see if the shaft shows a dimple or a hole.. or if handle is rusted in place and won't move on the shaft when operating the throttle handle, then go without looking further.. what I'd do..
