John Deere 990 Steering Wheel
   / John Deere 990 Steering Wheel #1
gizmo
Jonesboro, GA
2002 JD990
Ok, its been a while since I was on here, but I broke the instrument panel glass on my 990 and now I'm trying to replace it. Unfortunately, I have to deal with what has to be one of the dumbest design decisions in tractors or automotive in general: a pressed on steering wheel. Someday I'll find the moron that made that decision. Anyone know of a good way to get the wheel off? Is there a specialized puller, or do I just need to cobble something together? For now I have just left the nut off and maybe it might loosen.
   / John Deere 990 Steering Wheel #2
Sometimes looking over the parts manual or www.jdparts.com will give me an idea how to tackle the problem. Or, you might find a downloadable *.pdf file for the technical repair manual on www.johndeere.com.
AKfish
   / John Deere 990 Steering Wheel #3
The tech manual for my 2010 3520 says to loosen the nut and use a suitable puller........r i g h t.
And to lubricate the spline with a "suitable lubricant" for easy removal later.
If you have a helper, I've been successful with one person pulling up on the wheel while I tap on the loosened nut with a little penetrating oil on the splines.
If you have a helper, I've been successful with one person pulling up on the wheel while I tap on the loosened nut with a little penetrating oil on the splines.[/QUOTE]
Tried that. Even used an air hammer. No joy, but nearly wrecked the nut and shaft end. I have since ordered a giant bearing splitter and 5 ton puller. Something will give.
   / John Deere 990 Steering Wheel #5
Yes, there is a specialized "steering wheel" puller. See if one of your local auto parts store has one to rent as it should be a better quality puller if they do. You can buy harmonic balancer/steering wheel puller sets for less than 20 bucks. I'd definitely get one before I'd mess with it.
New/Unused 70in Quick Attach Seeder (A51573)
New/Unused 70in...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 JOHN DEERE...
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
2016 Sure-Trac 20 Ton Pintle Trailer, VIN # 5JW2U2522G1121114 (A51572)
2016 Sure-Trac 20...
