John Deere 955 transaxle or transmission problem
   / John Deere 955 transaxle or transmission problem #1
MarkVallon
AnnArbor, Mi
John Deere 955
Hi there. When I press r?he reverse pedal on my John Deere 955, it begins to move, but when the load increases (backing up a hill or over a step) it's like it jumps out of gear, stops and you hear gears grinding against each other. It will driver forward OK, unti you realease the pedal. Instead of slowing down, it's also like it jumps out of gear, it contnues to roll as if you've pushed in the clutch and you also hear the gears grind. It al ost seems like something is free-wheeling in one direction, but not the other. Any help would be appreciated. Thanks!
2025 Swict 66in Bucket Skid Steer Attachment (A50322)
2025 Swict 66in...
1991 International 4900 Box Truck (A51039)
1991 International...
2020 KUBOTA SSV75 WHEELED SKID STEER (A51242)
2020 KUBOTA SSV75...
2015 MACK GU713 (INOPERABLE) (A50854)
2015 MACK GU713...
2006 International 4400 LP Crew Cab Heavy Haul Truck Tractor (A49461)
2006 International...
BREWSTER DRAWWORKS WITH TWIN CATERPILLAR ENGINES (A50854)
BREWSTER DRAWWORKS...
