John Deere 955 part identity request
   / John Deere 955 part identity request #1
jgwhite
Arnprior, Ontario
John Deere 955
Hello All,
I am looking for the name or identity of the part in the photo attached. It is on the Governor throttle linkage which the throttle cable wire in secured to. the one with the threaded screw into the square block attacked to the linkage A and B. The person who had my 955 before must have lost it and then just wrapped the wire through the hole and twisted it around. I would like to replace that part. Would be even better if I could get a part number but I have not been able to locate it through the JD parts catalogue.
All help is greatly appriciated.
Cheers,
John
955 FEL
   / John Deere 955 part identity request #2
Go look again in sectional index #30-Fuel and air and then #22-Governor housing & linkage
It's called a Clamp- M800052
Thank you Barry,
I also found it under Alphabetical in Throttle and cruise controls #17
I don't know why I missed it when it was right in front of me.
I would be nice instead of zooming on the part section window that the whole window would get bigger.
Thanks again,
John
PICK UP BED (A49461)
2003 Wells Cargo Enclosed Gooseneck Trailer (A50860)
2003 Wells Cargo...
2018 Ford F-250 Ext. Cab Reading Enclosed Service Truck (A48081)
2018 Ford F-250...
2017 Crane Carrier Co LET2 Side Loader Garbage Truck (A48081)
2017 Crane Carrier...
Hay Fork (A50860)
Hay Fork (A50860)
8ft S/A Utility Trailer (A48082)
8ft S/A Utility...
