John Deere 950
   / John Deere 950 #1
Dirtdigger5
Sherwood Park, Alberta
JohnDeere 950
I have a 1984 JD 950 tractor with front wheel assist. I am in the process of replacing the lower oil seal (part #CH17593) in the lower left hand final drive housing of the front wheel. This seal replaced (at some point prior to machine serial no. 020000) two oil seals, the top one with open side facing up and the lower with open side facing down. The parts manual records this change but the service manual does not indicate if the open side of the replacement seal should face up or down. The service manual records a seal driver part number for both removing and replacing the seal but there is no way to get at the seal with a driver if you installed it with the open side facing down. Has anyone any experience with replacing this seal and know which way it should face?
UNUSED FUTURE MINI SKID STEER PALLET FORKS (A51244)
UNUSED FUTURE MINI...
Army Semi Trailer (A50774)
Army Semi Trailer...
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
Unused Delta Crash...
UNUSED AGT QUICK ATTACH AUGER SET (A51244)
UNUSED AGT QUICK...
1996 FREIGHTLINER FL70 S/A GRAIN TRUCK (A51243)
1996 FREIGHTLINER...
