TimberHole
Platinum Member
- Joined
- Jul 17, 2017
- Messages
- 524
- Location
- Missouri
- Tractor
- JD9504WD w/ 75 Loader, JD345, Bobcat S150
I just acquired a John Deere 950 from a friend. The tractor is in excellent shape and only has about 1,000 hours. The tractor is getting oil in the radiator but does not have water in the oil. Starts and runs perfect but I'm told it is overheating and will blow the cap off the reservoir. The previous owner replaced the head gasket but did not have the head magnafluxed or die penetrant tested. I'm fairly handy around a gas engine but completely new to diesels. I was talking to the folks at Hoye Tractor today and they suggested also posting on this site. Nice folks by the way.
I'm hoping this is a head or gasket issue but think it could also be a cracked block.
Here is my plan (mostly of my own creation):
1) Compression test
2) Pressure test each cylinder. Piston at the bottom, valves closed and 125 psi from the compressor in the injector port. Hoping this isolates the cylinder.
3) Pull head and have it evaluated by a competent machine shop. Check deck for flatness and head for cracks.
4) If none of this yields fruit, pull the pan, inspect for cracks and start the head scratching.
Am I overlooking anything obvious? It is my understanding that this engine does not have any type of oil cooler. Is there any other probable location where oil could enter the water jacket?
If anyone has had a similar issue or has any wisdom to offer I would sure appreciate hearing from you. This is a really nice little tractor and I'm committed to resolving this.
Thanks in advance.
1) Compression test
Thanks in advance.
