John Deere 855
/ John Deere 855 #21
No need for a clutch on a hydrostatic machine. Also, you may have be rolling in order for the gears to mesh and allow you to shift into 4wd. Generally you have to back up just a little to "unload" the gears to allow you to shift back into 2wd.
I shift on the fly all the time. One thing I avoid is if I'm spinning the rear wheels, I don't slam it into 4wd unless I'm making good headway. I don't like the idea of torque hitting the front end like a BFH hitting a finish nail.
/ John Deere 855 #22
Instead of stopping and backing up to relieve gear-bind, I've also notice that I can unload the gears by turning. So, when I'm mowing the field and come across an area where I want 4WD, I engage it. Then when I don't need it anymore, I will wait until I get to the end of a row where I'll be turning and apply light pressure to the shift lever. As the turn progresses and the gear-bind unloads, the lever will drop back to 2WD easily.
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
2025 Hydraulic Tilt Bucket Mini Skid Steer Attachment (A59228)
2025 Hydraulic...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
2007 Nissan Frontier SE Crew Cab Pickup Truck (A59230)
2007 Nissan...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A61307)
2024 Kubota...
2020 GMC Sierra 1500 SLT 4x4 Crew Cab Pickup Truck (A59230)
2020 GMC Sierra...
