John Deere 855, lost 4-wheel drive, and fixed it.
   / John Deere 855, lost 4-wheel drive, and fixed it. #1
lennypoulin
North Brookfield, MA
JD 855
I lost the 4 wheel drive (front wheels) on my 1986 John Deere 855. Thanks to other posts on this site, after jacking up the tractor, front and rear, I physically looked at the drive shaft, while running and engaged, to see if it was turning.
The drive shaft is covered with a plactic outer tube and rubber boots at the U-joints. So, you have to first loosen the rubber boots, both ends and slide back to view the u-joints. The u-joint of the driveshaft was turning at the hydraulic transmission, but not at the front axle. I couldn't find information anywhere on how this u-joint comes off! No bolts anywhere, splines on both ends. I finally discovered that you have to turn the shaft to locate a split tension pin, viewable through a u-channel opening on the boot collar, and with a good punch, drive out the pins on both sides.
My problem was a sheared pin on one end only, and the driveshaft pipe rotated freely in u-joint yoke, thus not engaging the front axle. I found the right diameter tension pin at Lowe's for $0.39 cents. Easy fix, if you know how to take off the driveshaft.
If anyone else has this problem, look at the driveshaft first before digging into gear boxes. I hope this saves someone the same frustration I had trying to take off the driveshaft.
   / John Deere 855, lost 4-wheel drive, and fixed it. #2
Thanks for the insight, and fix. I'll hopefully remember this, if it ever happens to mine. Heck, this thread will hopefully/probably come up in the "search" results...
   / John Deere 855, lost 4-wheel drive, and fixed it. #3
Thanks for the tip. My dad's compact Deere 2210 currently does not engage the front wheels either, needs investigation.
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A51039)
2016 Kawasaki 70...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A51039)
2018 Dodge Ram...
2005 WINNEBAGO WORKHORSE W22 RV (A50854)
2005 WINNEBAGO...
2017 John Deere 30G Mini Excavator (A50322)
2017 John Deere...
2020 CATERPILLAR 289D3 SKID STEER (A51242)
2020 CATERPILLAR...
