John Deere 855 Hydraulic Problem
   / John Deere 855 Hydraulic Problem #1
jimsing
1997 JD 855
Hi all, I have a JD 1998 855 25 Hp hydrostatic drive and when the tractor gets hot, the transmission slips but the front end loader works fine. I changed fluid, filter and cleaned the screen, which looked good, and that didn't help. I then put new O-rings in the pump and that didn't help. I then changed out the hydraulic pump with another used pump and it helped some but it still slips once you work it hard for half an hour or so. Any other thoughts outside of taking it to the dealer and letting them have their way with it?
Would changing over from HyGard LowVis to HyGard HighVis help?
Thanks in advance
   / John Deere 855 Hydraulic Problem #2
In a hydrostatic transmission the main tractor hydraulic pump has next to no involvement in the HST operation.
Suggest you post in a JD section of this forum as your problem is really not hydraulic
Dave M7040
   / John Deere 855 Hydraulic Problem #3
Hydrostatic transmission might have a charge pump.
Dave M7040
Thanks Dave. I think we've figured it out. I replaced the HyGard LowVis with 15w40w oil, suggested by the local JD dealer, and it seems to be working a lot better. At least for now.
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
1986 John Deere 772B Articulated Motor Grader (A49461)
1986 John Deere...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A50854)
2014 FORREST RIVER...
American Sanders Super 7R Electric Wood Floor Edger (A49461)
American Sanders...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
