John Deere 790 with Dual, Clutch Frozen
   / John Deere 790 with Dual, Clutch Frozen #1
mds1315
Bellingham, MA
To Many!
2003 John Deere 790 with 75hrs on it that was in a slight flood and sat for two years. It runs fine but the Clutch is stuck and wont go in gear. The PTO works fine with the clutch so I know that one of the clutches is free. Any suggestions of freeing up the main clutch with out splitting the tractor?
Any help would be appreciated!
Matt
   / John Deere 790 with Dual, Clutch Frozen #2
Problem is disc rusted to flywheel. Try putting in low gear. with engine off. step on clutch and hit starter. This sometimes will break them free. Might also try, engine off put in gear, step on clutch and pull tractor. If there is as inspection hole where you can see the edge of the clutch have a helper step on clutch and try to drive something like a screwdriver between the disc and the flywheel and the disc and the pressure plate.(but of course you would never drive on a screwdriver;)). I hope it works for you I have an old model 15 Cat that I need to pull because nothing worked.
   / John Deere 790 with Dual, Clutch Frozen #3
I know this is an old post but I have the same issue after a flood and wanted to find out how you got it fixed?
Any help would be great. Thanks
Matt
AIR COMPRESSOR & PUMP (A48992)
AIR COMPRESSOR &...
Lyom-053 Unassembled Safety Basket Forklift Attachment (A46683)
Lyom-053...
2001 Dodge Ram Ext. Cab Pickup Truck (A48081)
2001 Dodge Ram...
2019 Ford F-550 V-Mac DTM70 Air Compressor Flatbed Truck (A48081)
2019 Ford F-550...
2011 Terex Fuchs MHL340 Wheeled Material Handler (A49346)
2011 Terex Fuchs...
45031 (A48082)
45031 (A48082)
