John Deere 7820
   / John Deere 7820 #2
To Recall Codes from All Controllers:
Press and hold the “Vehicle Settings Switch” and the “Lower Hitch Set Switch” simultaneously while turning Key Switch to RUN position (engine off). A menu listing of the Controllers will appear on the CommandCenter display.
Turn “Command Dial” to highlight ” All ” in the menu.
Press “Select Switch”. Entire display will read ” All ”.
Turn “Command Dial” to scroll through list of controllers. Controllers with stored codes will display the word ” Code ” and the “Next” icon (triangle pointing right). Controllers with no stored codes will display the word ” None ”.
Press “Select Switch” to display first code of desired controller. Display shows the diagnostic trouble code number and the “Back” icon (u-turn arrow).
If controller has more than one stored code, turn “Command Dial” to scroll through list.
Press “Select Switch” when ” Clr? ”and the “Next” icon appear on display to clear code(s) for that controller.
Entire display will read “ Done ”with and the “Back” icon. Press “Select Switch” to go to the next controller or scroll to the “All” at the top of the controller list.
Press “Select Switch” when “ All ”and the “Back” icon appear on display. This exits the codes from all controllers.
   / John Deere 7820
Thank you. I figured it out. One of my workers took the SSU fuse out for some reason
Bryant 650AN048-E A/C Unit (A52377)
Bryant 650AN048-E...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2013 Chevrolet...
Case 580M Series 2 Loader Backhoe (A53117)
Case 580M Series 2...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A53473)
2023 NEW HOLLAND...
2015 Nissan Altima Sedan (A51694)
2015 Nissan Altima...
