John deere 7810 Used.
   / John deere 7810 Used. #1
Edward. S
Platinum Member
Somewhere
John Deere
My dad might buy a 7810:D with 2500 hours :confused: on the clock for around $70,000 is it worth it. It has a Powerquad + 16/16. Just like my 6420 :p
Has around 150 Pto hp. factory duals. Front weights don't know how many. Probably about 12-14 Front weights. 47kg each.
   / John deere 7810 Used. #2
If those hours are accurate that would be a VERY low houred 7810...that being said I would think 60-65K would be more in line, but if the tractor is excellent and good tires 70K wouldn't be too far out of line. We sold two earlier this year for around 60K with 3000-3500hrs on them.
   / John deere 7810 Used. #3
From what I can tell this forum has experience with 5000 machines and smaller. Most members here have little or no experience with larger tractors. Good luck shopping.
   / John deere 7810 Used. #4
If it is not MFWD, I would say that is on the high side. How many hydraulics, loader ready, condition of tires, stored inside or out and other options will affect price? 2WD just doesn't sell as well any more. Many farmers will pass on a tractor like that unless it is a backup or secondary tractor. Green paint always seems to command more $$. I have a JD 4520 CUT. Other newer tractors are 2008 CASE-IH 125 Maxxum PRO (125hp) and 245 Magnum (245hp) both with MFWD. These were our first MFWD larger ag tractors. My 125 will out spec a similar sized JD 7230, has more options and cost 20K less. I was originally wanting a JD but have been very satisfied with my CASE-IH.
We traded our Case-IH 2wd 8930 (180 pto hp) in for the 245. The 8930 is a litlle bigger than the 7810. It had 3,900 hours and was in good to very good condition. We got 55K for trade-in after bargaining for the new tractor. The 8930 was resold from the dealer in a month.
Its MFWD with 3 sets of scvs the all of the tires are around 70%.
   / John deere 7810 Used. #6
Its about 10-15 grand too high from the market around here.
10,000 - 15,000 are you crazy.................
2025 AGT YSRT14 (A50123)
2025 AGT YSRT14...
INVERTER TIG 350A WELDER (A51248)
INVERTER TIG 350A...
UWS TRUCK BED TOOLBOX (A51248)
UWS TRUCK BED...
2025 INDUSTRIAS AMERICA FT510 5'X 10' HYD DUMP TRL (A51247)
2025 INDUSTRIAS...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
