MoparMuscl
I have a 1998 John Deere 755 with a Yanmar 3TNA72UK engine. It ran fine until last year when it started to act like it was out of fuel occasionally. It made it through the summer until last fall when it wouldn't run well after it was running for 5-10 minutes. The past couple weeks I have tried to use it, but it is doing the same thing. It acts like it isn't getting fuel, then stumbles at a low rpm, catches up slowly, and runs wide open again for a second or two before the process starts again. I put a new electric fuel pump on it last week, but it didn't help. I put some clear lines on the pump to filter, the filter to injector pump, and the return line from the front injector to the tank. There is no air getting in the system before the high pressure injector pump. As it starts to stumble, air bubbles start to pass in the return fuel line and go back to the tank. After several air bubbles pass and it is solid fuel in the return line, it runs good for a few seconds until the process starts again. Once I let it cool, it runs fine again for a little bit.
Has anyone run across this problem, or have any suggestions I need to check? Thanks in advance!
