John Deere 755 loosing idle
   / John Deere 755 loosing idle #1
gunnerdog
Owego, ny
Kubota B7200hst
Hello......was wondering if someone could help me out with my john deere 755. It starts right up fine, but when just sitting idling it looses rpm`s, and when you try to go forward or reverse the rpms drop right off. Changed fuel filter but that didn`t help......Not sure where to go from here, Like I mentioned starts right up fine, no problems at all....thanks in advance for any help you might be able to offer.
Nobody has any ideas as what might be causing my problem? please help!! Thanks
   / John Deere 755 loosing idle #3
You're gonna need to give us more info. What happens if you throttle up? Does it run okay then? You say rpms drop at idle. Does it actually stall, or keep running at a lower idle speed? How low is low? How many rpm's on the tach at a steady idle speed?
   / John Deere 755 loosing idle #4
Make sure the fuel shut off solenoid is remaining fully engaged, and not somehow sliding back toward off position. Start and run positions are controlled separately.
   / John Deere 755 loosing idle #5
I sound like a broken record but is your. Electric fuel pump running ? The brass screen in the tank can plug up also with Algae
2012 John Deere 7280R MFWD Tractor (A51039)
2012 John Deere...
2006 BOBCAT S130 SKID STEER (A51222)
2006 BOBCAT S130...
2017 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A49461)
2017...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2011 TROXELL 140BBL TRIAXLE VACUUM TRAILER (A50854)
2011 TROXELL...
John Deere 4020 Tractor (A50514)
John Deere 4020...
