John Deere 730 LP conversion to Gasoline
   / John Deere 730 LP conversion to Gasoline #1
Deck III
A friend of mine has several old LP 730 tractors and is wanting to convert one to gasoline. I was just wondering what all is required. I am not a professional by any means and was hoping to recieve a little help from this forum. My thinking is that a fuel tank, carburetor, settlement bowl, and throttle adjustment would handle most of the project any help would be greatly appreciated.
   / John Deere 730 LP conversion to Gasoline #2
Possible intake manifold. Propane doesn't require a vertical carberator mount.
   / John Deere 730 LP conversion to Gasoline #3
I can't say for certain about the two cylinder tractors but I came close to purchasing a 4020 tractor that had been converted from LP to gasoline. The compression ratio is higher on the LP tractor as they use different pistons. My dealer had a concern about using regular fuel and thought I would need to use premium to avoid detonation. I never bought the tractor.
It may not be an issue with the 730 and even if it is you probably aren't putting a lot of hours on the tractor where a few extra cents for premium fuel would be a problem. The 4020 gasoline tractors were quite thirsty so I was reluctant to spend the extra for premium fuel.
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
2020 CASE CX37C EXCAVATOR (A51242)
2020 CASE CX37C...
72In FEL HD Round Back Bucket (A51039)
72In FEL HD Round...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2019 Ford F-550 Bucket Truck (A51039)
2019 Ford F-550...
