mguitas
Super Member
- Joined
- Aug 22, 2011
- Messages
- 8,080
- Location
- Schuylkill County Pennsylvania
- Tractor
- Massey Ferguson 1423 Hydrostat
Ok guys! I will give as much info as possible. Problem... 710c works perfectly one day. Next day after using backhoe for 5 minutes I noticed an audible drop in engine rpm and the Hoe bucket and dipper stick were sluggish. I tried to open the throttle to increase rpm....made no difference. It eventually stalled the motor. this condition still remains. what I researched and tried so far. Drained fuel replaced fuel filter. Found that the destroke solenoid at the main hydrauylic pump was bad. I replaced it. I cleaned both air filters. I reattached the torque converter solenoid that had been torn from its harness. I have no visible leaks beyond some cylinder seal seepage that is minimal. I checked my control linkages ,all seems ok? NOW, when I purchased this used it had a broken differential lock pedal. The pedal is in its locked position but I don't think that would be any problem. Lastly, my curl stick for rear bucket does get stuck while curling on occasion but this has always done this since the purchase 3 yrs ago. Not sure where to look next. I have been told that it seems to be a fuel problem....not hydraulic. Any advice would be appreciated.
