Planters John deere 70 and 71 planters
   / John deere 70 and 71 planters #1
deere755
Platinum Member
central Illinois near Lake Shelbyville
Case 2090 Massey Ferguson 4233 John Deere 4700
What is the major difference in the 2 planters? Do both have different population settings? Do they use the same plates as the 494's do? I am thinking about buying a 70 model. I would like to be able to change planting populations and have settings I can trust. My 494 is just guess work, I have two sprockets and 2 plates to choose from 16 cell and 24. I planted some corn earlier this year with mine and we thought we were around the 30,000 ppa range but some where along the way we started dropping 2 at a time part of the time and ended up with 44,000 ppa standing corn. I am not sure why all the sudden it started dropping 2 at a time part of the time. In some areas we have 29000 ppa I can live with that.
After posting this tread I did a search and answered all my own questions. Kinda like if all else fails read the directions.
   / John deere 70 and 71 planters #3
NBD...It just gets everyone thinking...:D
   / John deere 70 and 71 planters #4
As the production of #71's went along, there were improvements to the design. Later models have quite a few differences, especially in the toolbar mounting hardware. The biggest difference between the 70 and 71 is the drive chain tensioning adjustment. 70's used three bolts through slotted holes to adjust the packer wheel axle to tighten/loosen the chain, where the 71 used a spring loaded idler sprocket with-in the chain housing. The down pressure tensioning adjustment was improved and made more reliable on the 71's. 71's also offered improved, more supple suspension on the "flex" frame.
The first 70's used roll pins to attach seed drop drive sprockets to the shaft they run on. The last of the 70's and then ALL the 71's employed a threaded axle and sprockets.
71's had provisions to attach a fertilizer system, however few were actually sold with those fert. units.
I've got 2 of each. (70's and 71's) If I was buying, for my money, there isn't enough difference in the 2 to warrant a significantly higher price for the 71's. The "time saved" in adjusting chain tension while changing sprockets is about a minute. You won't need a wrench to adjust the chain on a 71 where you will on the 70, but you DO need tools to change the sprockets themselves, so no real advantage there. The down pressure adjustment on the 70's is a little crude in appearance compared to the 71's, but they BOTH work adaquately and very consistant. The only time you'll see any advantage to the suspension differences is IF you plant in a rough seedbed at VERY high ground speeds (for a planter.....above 6 to 7 MPH)
A NEGATIVE with the 71's (comapred to a 70) is the 71's DO NOT like to have the packer wheel turned in reverse. They have a tendency to derail the chains if you accidentally back up with the packer wheel still in contact with the ground. (And that does happen) You have no way of knowing if the chain derails until your corn doesn't come up) 70's tend to ignore accidental reversing.
Long story short, I own both, have USED both, and can't see ANY difference in their ability to accurately plant.
One cause of "double seeding" is often too large of a cell on the seed plates and/or inconsistant sizing of the seed itself. With the move to modern PLATELESS planters that will plant different sized seed at accurate spacings, I've noticed less effort by seed corn producers to consistantly size their seed.
I would have to agree on the seed companies not spending a lot of time grading seed. This was a very cheap brand of seed corn my BIL bought for $54 at a local farm store so that tells you a little more also. I walked all over the area we planted and you can see where all the sudden the planter started planting thicker and towards the end it did a pretty good job. I believe we got in to a smaller seed for a while and that is why we got it so thick.
   / John deere 70 and 71 planters #6
I'm looking to mount a second planter on my tool bar but I need another packing wheel for the other planter I have. Does anybody know where I can find one. Otherwise I'm thinking to build one out of 12" pipe and flat plate. Then machine the axle hub to press onto the shaft. found a replacemnet bearing asembly at a water pump rebuilder, and only have to shortin it on both ends.
   / John deere 70 and 71 planters #7
I have a couple of 71 packing wheels, I will send you a PM.
   / John deere 70 and 71 planters #8
Looking for a 70 - 71 john deere flex corn planter. Live in Kansas. Anybody know where I can get one close to my area.
2018 Ford F450 (A49461)
2018 Ford F450...
2013 GMC Sierra 2500HD 4WD Pickup Truck (A50860)
2013 GMC Sierra...
UNUSED 20PCS 2in. Polyester Lifting Strap (A50860)
UNUSED 20PCS 2in...
2022 Case IH Steiger 420HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2025 K4525 UNUSED Double Garage Steel Barn (A50860)
2025 K4525 UNUSED...
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A51039)
2017 Ford F-550...
