John Deere #7 Backhoe on Yanmar 1500D
   / John Deere #7 Backhoe on Yanmar 1500D #1
mikehalm
Yanmar 1500D, Yanmar 186D
Anyone know if a JD #7 backhoe will bolt up to the frame of a Yanmar 1500D?
Thanks for any information you might provide.
Mike
   / John Deere #7 Backhoe on Yanmar 1500D #2
I would expect you'll need to fab up your own subframe, or have one made for you. Even though many JD compacts were made by Yanmar, you won't find alot that interchanges between the tractors.
Thanks Ductape.
Can fabricate a frame. Do you think that these size of the JD #7 id compatible with the Yanmar 1500D? It was my understanding that the #7 was built for a JD compact. The information I found was that is was designed for JD 790, 770 and 3005.
Mike
   / John Deere #7 Backhoe on Yanmar 1500D #4
Thanks Ductape.
Mike
I thought the 1500 was a frame size smaller than the 790....yes? If so, the hoe may be too much for it.
   / John Deere #7 Backhoe on Yanmar 1500D #5
How much does the hoe weigh and how much does the tractor weigh and or how deep does the hoe dig.
Craig Clayton
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
1989 SHOPBUILT THREE AXLE LOWBOY TRAILER (A50854)
1989 SHOPBUILT...
2019 FREIGHTLINER CASCADIA DOUBLE BUNK SLEEPER (A51222)
2019 FREIGHTLINER...
STORAGE FEES (A51222)
(2) 300 GAL WATER TANKS (A50854)
(2) 300 GAL WATER...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR6BJ325793 (A51572)
2011 International...
