John Deere 67 Loader Control for 750 CUT
   / John Deere 67 Loader Control for 750 CUT #1
WilliamJP
The John Deere 67 loader mounted on my 750 John Deere tractor LEAKS hydraulic oil at the controls.
New loaders use a joystick control. I believe John
DEERE changed to a joystick on newer loaders to prevent oil leaks by the controls. Can I install a new joystick control unit in place of the present controls on the 67 John Deere loader? Will it be compatible?
   / John Deere 67 Loader Control for 750 CUT #2
Joystick controls only relocates the oil leak if one appears as they utilize basically the same type valve on both types. It's possible that your tractor oil leak could be cured with a seal and yes you can install a JS valve on your tractor.
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
2015 FREIGHTLINER CASCADIA (A53843)
2015 FREIGHTLINER...
RIDGID POWER DRIVE/HAND HELD THREADER (A53843)
RIDGID POWER...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
