John Deere 6615 steering noise
   / John Deere 6615 steering noise #1
pnhigg
Lexington
John Deere
I have a "new to me" 6615.
When steering there is a bit of a groan/moan from the steering motor under the dash. You can feel a very slight/fine vibration in the steering wheel while hearing the groan. Can't hear anything outside the tractor.
The tractor steers great, and all hydraulics work as they should. Filters and oil have been changed.
Of note, the groan goes away if one of the hydraulic levers are moved as you would lift or lower an implement.
As I said the tractor is new to me, just wondering if it is a noise common to these tractors, or something I need to dig in to, and if so where to dig first.
thanks in advance
   / John Deere 6615 steering noise #2
Steering noise is probably caused by a vibrating unloading valve in the priority valve. It doesn't cause any operational problem, but there is an updated valve available to alleviate this noise. Ask for AL170216 kit at your dealer if the noise bothers you. It applies to tractors above serial number 013840.
Thanks a lot.
that is exactly the type of information I was hoping to find.
thanks again
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2025 AGT LRT23 (A50123)
2025 AGT LRT23...
2018 John Deere 310L 4x4 Extendahoe Loader Backhoe (A52377)
2018 John Deere...
2025 CFG Industrial QK18R (A50123)
2025 CFG...
2012 Subaru Legacy Sedan (A51694)
2012 Subaru Legacy...
Unused 2025 Wolverine SBM-12-72W Sickle Bar Mower Skid Steer Attachment (A51691)
Unused 2025...
