john deere 6610 instrument cluster/dash board problem
   / john deere 6610 instrument cluster/dash board problem #1
GER6610
cork
john deere 6610
The warning lights on my 6610 dashboard have failed completely.
The LCD display,fuel,temp gauges,Tacho all work perfectly.
initially the lights were very dim.Especially when activated turn signals.
when i turn on ignitition key the time clock on LCD display goes to zero.. there is also a slight grinding/tearing noise from the dash..
i have removed the unit and visually inspected it. however i can see no obvious problem.I am a little cautious not to interfere with it and damage the unit.
can anyone advise as to possible reasons for this issue?
   / john deere 6610 instrument cluster/dash board problem #2
My first thought is you have a bad ground some where that relates to the cluster.
   / john deere 6610 instrument cluster/dash board problem #3
Hi, I know this problem was 4 years ago, but did you ever get to the bottom of it? I've got a 6410 with exactly the same problem and would appreciate any advice!
Thanks.
GER6610
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2018 FREIGHTLINER...
2020 KENWORTH W900L DAY CAB (A52472)
2020 KENWORTH...
2021 KUBOTA SVL75-2 SKID STEER (A51246)
2021 KUBOTA...
2002 CHEVROLET C&K SERIES 7500 CAB & CHASSIS (INOPERABLE) (A52472)
2002 CHEVROLET C&K...
2013 John Deere Gator 825E (A51573)
2013 John Deere...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
