JOHN DEERE 6420 RUNNING ROUGH
   / JOHN DEERE 6420 RUNNING ROUGH #1
FBRECH
belle chasse
john deere 6420
6420 RUNS AND IDLES ROUGH, GOT CLEAN FUEL AND FILTERS, ANY IDEA'S
   / JOHN DEERE 6420 RUNNING ROUGH #2
Has been some issues with the electical fuel transfer supply. Not all s/n's were the same pump though.
   / JOHN DEERE 6420 RUNNING ROUGH #3
I would star by replacing all of the rubber hoses from the fuel tank to the fiters, transfer pump, and fuel cooler. These have been known to get small cracks or pinholes and allow air to get in the fuel lines. The transfer pump can be going bad also. If you install the upgraded new one, it absolutely needs to have fuel lines rerouted correctly or the pump will over-pressurize the injection pump and will make it run rough and can damage the injection pump.
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2013 TRAVIS BODY & TRAILER, INC. ALUMINUM BELLY DUMP (A50854)
2013 TRAVIS BODY &...
2021 Ford F-250 4x4 Ext. Cab Pickup Truck (A49461)
2021 Ford F-250...
2010 SHOP MADE WINDMILL TRAILER (A50854)
2010 SHOP MADE...
2017 DITCH WITCH RT30 RIDE-ON TRENCHER (A51242)
2017 DITCH WITCH...
2019 CATERPILLAR D6N LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
