John Deere 6420 powerqaud 24 speed Foaming oil
   / John Deere 6420 powerqaud 24 speed Foaming oil #1
Hank69
Northern Ontario, Canada
JD
Hey all Newbie to the site, I'm hoping to find some info on the John Deere powerqaud 24 speed as used in the 6420, I have been helping a friend with this unit but now at a stand still, The trans/hydraulic oil is foaming/airating excessively causing the loader and steering to be very jerky and chatter. The main pistion pump has a charge/lift pump that supplies oil to the piston pump, we are at the point where I'm starting to suspect the suction tube suppling the charge pump may have cracked and is causing the charge pump to be the source of the foaming/airation in the oil. Has anyone had any similaiar issues with these transmissions?
2007 Ford Taurus SE Sedan (A51694)
2007 Ford Taurus...
2014 FREIGHTLINER 108SD WITH ELLIOT H110 CRANE/MANLIFT (A52472)
2014 FREIGHTLINER...
2011 TROXELL 130BBL (A52472)
2011 TROXELL...
2020 COLOMBO TM LOT NUMBER 216 (A53084)
2020 COLOMBO TM...
48 PIECE HEAVYEQUIPMENT KEY SETS (A52472)
48 PIECE...
