John Deere 6403 clicks but won't start
   / John Deere 6403 clicks but won't start #1
M16
New Holland 6610S
My JD 6403 makes a clicking noise when I turn the key. I had the battery tested and it showed to be good. I bought and installed a new battery anyhow since the other one had some age. Any thought as to what my problem might be? Thanks.
   / John Deere 6403 clicks but won't start #2
Have you checked/cleaned & tightened securely all 4 battery cable connections?? If so then I vote starter problems.
   / John Deere 6403 clicks but won't start #3
Are you getting multiple clicks when you try to start or a single click? Multiple clicks usually indicate low voltage due to weak battery, dirty connections, or bad cables. A single click could be a bad starter, starter relay, neutral switch, etc. It helps to know where the clicking is coming from.
Got it fixed. It was multiple clicks. Turned out to be the the ground at the frame was loose. I cleaned and tightened it. It fired right up.
   / John Deere 6403 clicks but won't start #5
Glad you got it repaired. I learned many yrs ago to always check the easiest/simplest things first.
2022 JOHN DEERE 331G LOT NUMBER 99 (A53084)
2022 JOHN DEERE...
2021 JOHN DEERE CP690 LOT NUMBER 196 (A53084)
2021 JOHN DEERE...
John Deere 6430 Side Arm Tractor (A51573)
John Deere 6430...
2014 Ford Escape (A50324)
2014 Ford Escape...
A1 MIST SPRAYERS RESOURCES TX3PT LOT NUMBER 85 (A53084)
A1 MIST SPRAYERS...
2004 Honda Odyssey Van, VIN # 5FNRL189X4B025339 (A51572)
2004 Honda Odyssey...
