Rake John Deere 640 Hay Rake Gear Box Maintenance?
   / John Deere 640 Hay Rake Gear Box Maintenance? #1
wjb-49
Lawsonville, North Carolina
LS MT573-CPS, Ford 4610
Hi everyone!
I have a John Deere 640 Hay Rake that operates fine, but I have a question regarding maintenance.
We have greased all fittings but do not know how to check the gear box lubricant. How do we check if the level is correct and what type of lubricant is used? Also, if we take the access plate off the gear box housing, would the seals have to be replaced?
As always, thanks for your help.
   / John Deere 640 Hay Rake Gear Box Maintenance? #2
WJB, has anyone replied to your question. I have the same issue with my 640. There does not appear to be a fill plug for the gear case. It would lead me to believe one has to remove the gear case cover to add grease, in which case how do you know how much to pack it with?
   / John Deere 640 Hay Rake Gear Box Maintenance? #3
There is a small plate on the end of the gearbox where some service could be performed but the unit should be taken apart for full service.
I am rebuilding my new 640 purchase and the gearbox failed due to a lack of service.
The unit is packed with a low grade,wax base grease that just collected moisture and all the bearings failed.
   / John Deere 640 Hay Rake Gear Box Maintenance? #4
Thanks. Yes, the gearbox has a service opening that is sealed with what looks like a freeze out plug. I've been reluctant to remove it since I don't know the availability of replacement plugs. I guess I'd better look into it so I don't repeat your unfortunate experience.
Regards,
Don
   / John Deere 640 Hay Rake Gear Box Maintenance? #5
The gearbox has a service opening that is sealed with what looks like a freeze out plug. I've been reluctant to remove it since I don't know the availability of replacement plugs. I'm just going to measure it up and find a compatible plug for that opening. Some models actually had a removable and reusable plug. I'm not that lucky. In any case it's a good idea to check the gear case for any water that could have leaked in and to top off the grease.
   / John Deere 640 Hay Rake Gear Box Maintenance? #6
On my unit there is a small,round plate that is held on with 4 small bolts.
The plug that you are referring to is an insert plug that is the back side of the axle drive bearing.
I am convinced as I work through my project that the unit is not designed to hold oil or any liquid lube and requires grease and the lubrication is not "flung" as the gears turn and so the dirt or wear is held in the grease.
   / John Deere 640 Hay Rake Gear Box Maintenance? #7
My gearbox has only the "freeze out" plug. Others have responded that the lube is a heavy grease and not gear oil, probably why these units never seam to leak oil. Thanks for the response.
Sorry to be so late in thanking all of you for your replies. My rake has a plate held in place by bolts, so it's time to check if the grease is good. Thanks much!
   / John Deere 640 Hay Rake Gear Box Maintenance? #9
Update: Last year I had to replace the gear box bearing. Upon removal of the front cover, water dripped from the gearbox. The engage/disengage selector is not sealed well and water must seep down the selector shaft into the gearbox. While apart I drilled and tapped an inspection port in the gearbox and sealed it with a pipe threaded plug and a rubber gasket for future addition of lube.
Thanks for sharing your experience with another good ol' JD 640 hay rake. 😎
2005 Kenworth T-800 Tri-Axle Dump (A42021)
2005 Kenworth...
2002 Ford F-450 Super Duty 12ft Flatbed Truck (A42742)
2002 Ford F-450...
2015 VERMEER TRENCHER (A45046)
2015 VERMEER...
2016 Chevrolet Equinox LS SUV (A44572)
2016 Chevrolet...
VOLVO EXCAVATOR  EC330CL (A45046)
VOLVO EXCAVATOR...
2006 Club Car DS - CUSTOM 48V Luxury Golf Cart (A44789)
2006 Club Car DS -...
