John Deere 6200 problem
   / John Deere 6200 problem #1
Charco Kid
Goliad,Texas
John Deere 6200
Hello, I am new to your site and hope someone out there might help. My 1997 John Deere 6200 (2000 hrs.) will not always move when put into gear. Some days I have no problems, but here lately it will not move when placed in any gear. I can shift thru the gear ranges when tractor is running and no grinding occurs. It has a syncro transmission. Is there some type of switch or valve that is malfuntioning? Any help would be greatly appreciated.
Charco Kid
   / John Deere 6200 problem #2
The easy things to check/do are the hydraulic fuild level & condition. If it's dirty, milky change it and filters. Check for a burnt small too. If low top it off to correct level. Next thing could be a plugged filter.
There is an enagagemant overide valve and a clutch valve. Clutch pedal is also adjustable.
With only 2000 hours I doubt the clutch is bad unless it has really been abused. Or your hydraulic pump.
There are test ports near the hydraulic filter for checking pressures. If you have a guage and proper fittings to check. System pressure (for engaagement) is adjustable with shims. But I doubt this is the problem.
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
Assortment of Pipes (A50121)
Assortment of...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
2018 Ford Escape SUV (A50324)
2018 Ford Escape...
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
