John Deere 60 lose trany when shifting
   / John Deere 60 lose trany when shifting #1
1tinkerman
Avon, SD
Various
Model 60 here. Loose the transmission when crossing from one range to the other. Get it back by going to the other range and then coming back. Sometimes it take a few times before I get any gears again. Is this a simple fix or a serious task??
Wayne
   / John Deere 60 lose trany when shifting #2
I remember that dad had the same problem with an old B, didn't do it all the time, but was really frustrating when it acted up. I remember we took the shifter plate off and shimmed between the ball on the shift lever and the top plate, in effect making the bottom end of the shift lever extend further into the shift forks. My memory is really foggy, but I think we took a washer and dished it to fit the contour of the ball shape of the shift lever and put it between the ball and the top plate. If the 60 is different and this makes no sense, I understand. You just jogged my memory with the description of your problem.
1999 24DTA pintle hitch trailer (A51039)
1999 24DTA pintle...
2015 DODGE RAM...
2016 PETERBILT 587 (A50854)
2016 PETERBILT 587...
2011 FREIGHTLINER M2 26FT BOX TRUCK (A50505)
2011 FREIGHTLINER...
2004 JOHN DEERE 5320 TRACTOR (A51243)
2004 JOHN DEERE...
1267 (A50490)
1267 (A50490)
