John Deere 567 hydraulic cylinder
   / John Deere 567 hydraulic cylinder #1
rcpearce
ford 8600
John Deere 567 baler, hydraulic cylinder that opens and closes baler door is leaking oil around the seal. How do I take this apart to replace the seal?
   / John Deere 567 hydraulic cylinder #2
Welcome to TBN:D
I just looked in JDParts, they don't show the cylinder clearly enough to help you 100%, but they do list seal kits.
Can you post a picture of the end (where the rod exits)? Some gland nuts use snap rings, some are threaded, some need a special spanner...but basically you remove the gland nut, pull the rod out and replace the seals. It's a very easy job.
SCAN TO RECEIVE TEXT UPDATES (A52706)
SCAN TO RECEIVE...
Kubota BX2230D (A47384)
Kubota BX2230D...
2006 John Deere 925D Header W/Trailer (A53117)
2006 John Deere...
2019 Kenworth T270 Rollback Wrecker (A53117)
2019 Kenworth T270...
3 plastic drums (A53117)
3 plastic drums...
