John Deere 5425 won’t start as if the battery were dead but the lights work quite well
   / John Deere 5425 won’t start as if the battery were dead but the lights work quite well #1
DocJim
5425 John Deere
Tractor battery plenty hot but it’s like the battery is dead. Lights are very bright and readily come on. When the ignition key is turned on nothing happens.
   / John Deere 5425 won’t start as if the battery were dead but the lights work quite well #2
When this happens with fully charged battery the problem is usually one of the safty switches that prevent tractor starting. It's a matter of testing switches and their connectors. Try and find a wireing diagram for your model. It will show all switches. Meanwhile if you urgently need to use tractor you can jumpstart at solinoid. Just be double certain tractor is not in gear and be aware that fel,3 point or other hydraulics can move soon as engine starts. Be carful
   / John Deere 5425 won’t start as if the battery were dead but the lights work quite well #3
Welcome to TBN
Ditto on possible faulty neutral start switch. Is trans gear shift in neutral & pto control in off position?
   / John Deere 5425 won’t start as if the battery were dead but the lights work quite well #4
Are the terminals on the battery clean and corrosion free and is the ground lug to the frame also clean and free of corrosion? Lights draw little amperage, starter draws a bunch. High resistance connections will cause the starter not to turn (besides safety switches).
   / John Deere 5425 won’t start as if the battery were dead but the lights work quite well #5
Something els...check your groundcable...clean the ground and if that does not help...lenthern your groundcable and mount it to your engine .
I had 3 tractors that I had to change the place for the ground.
   / John Deere 5425 won’t start as if the battery were dead but the lights work quite well #6
Have you checked the cable connections? :geek:
   / John Deere 5425 won’t start as if the battery were dead but the lights work quite well #7
Long story short if everything checks out as the people above have suggested replace the ground cable. It can look OK but the inside can be corroded and prevent the starter from rolling over.
   / John Deere 5425 won’t start as if the battery were dead but the lights work quite well #8
And if replacing ground cable doesn't help replace the postive cable because it can do the same as ground cable. If that doesn't make it start replace the ignition switch because switch contacts can be corroded and preventing good contact. If all the afore mentioned checks out replace the battery because a battry can have 12 volts and enough amps to burn lights but not enough amps to turn starter. If that doen't help,,,,,,,,,,I'm reverting to my origional suggestion to test before replacing because the list is endless and a person can spend a lot of time and money replacing parts before stumbling onto the bad one.
Hmmmm, DocJim made his first and only post 1 week ago tomorrow and hasn't been heard from since. Wonder if he's still listening or moved on to bigger things? ⛹️‍♂️
   / John Deere 5425 won’t start as if the battery were dead but the lights work quite well #9
It could always be the starter. Put your voltmeter on the starter cable and see if the tractor so much as asks the starter to start. Brushes in the starter eventually wear out. If you have power applied to the starter ask someone to hold the key (or button) while you tap the starter with a rock, hammer, screwdriver handle, whatever. When the brushes go bad there is usually one or two more starts remaining that a bit of vibration can enable. This also helps a sticky starter solenoid.
If nothing at the starter then work your way back from there toward the ignition switch. Something between the starter contact on the switch (or your separate starter button?) and the starter is preventing your starter from turning.
   / John Deere 5425 won’t start as if the battery were dead but the lights work quite well #10
No one has mentioned fuses. Have you looked at them? Do gauges or warning lights on instrument panel come on when key is turned on? If fuse is blown, you may have the cold start sensor shorted out.
PALLET OF SPRINGS AND U BARS (A55745)
PALLET OF SPRINGS...
SEET BOX W/ CABLE SLINGS (A54757)
SEET BOX W/ CABLE...
Toro MBTX-2500 Concrete Buggy (A54865)
Toro MBTX-2500...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2013 FREIGHTLINER  CASCADIA (A55745)
2013 FREIGHTLINER...
2011 John Deere Tractor (A55973)
2011 John Deere...
