John Deere 5425 Starting Issues
   / John Deere 5425 Starting Issues #1
Davideg
Madison, WI
John Deere 5425
New member and expect a search of this subject may have some answers but have to post first before I can have access.
   / John Deere 5425 Starting Issues #2
:welcome:aboard, there is a John deere forum above. They could have the answer.
   / John Deere 5425 Starting Issues #3
Welcome to TractorByNet!
I moved your thread to the John Deere Owning & Operating forum. :)
   / John Deere 5425 Starting Issues #4
Davideg
:welcome:
What starting issues do you have. Will engine turn over but not fire or not turn over?
Davideg
:welcome:
Engine turns over well and actually starts almost immediately and runs for a few seconds before dying and then I have to crank starter for quite a long while before it will finally start. I do not run starter for more than ten seconds/approximately at a time. There have been a couple of occasions after a number of attempts that the battery is depleted to the point that I have to jump start. This only occurs when the tractor has been setting for a week or two. It never occurs if running every few days.
From a layman's point of view, it is like the fuel system has lost its prime and the fuel line has to be completely "recharged" before engine will run.
   / John Deere 5425 Starting Issues #6
I agree that more than likely fuel is draining back to tank letting air in fuel line. You could try installing a check valve to prevent fuel drain back.
   / John Deere 5425 Starting Issues #7
You have a minor leak in your fuel system. If it is functioning properly the fuel will not drain back. You need to check all connections and hoses including the return and make sure there are no leaks. Keep in mind that a connection or hose does not have to be leaking diesel to be leaking air. Check the filter too.
   / John Deere 5425 Starting Issues #8
Common problem with the 5X25 series, there is a flapper gasket in the filter prime pump, it either has dirt in it or needs to be replaced. Very common problem. Try taking it apart, and there is probably something in the one way valve that operates the prime hand pump knob...
Golf Cart (A48082)
Golf Cart (A48082)
Cosmo 3pt, PTO Spreader (A47371)
Cosmo 3pt, PTO...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A49346)
2025 Kivel 48in...
1999 Freightliner FLD 132, Tandem Axle Sleeper Cab (A47371)
1999 Freightliner...
Woods Snowblower (A49251)
Woods Snowblower...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
